belrangodoucet
Aug 13, 2014Aspirant
ST2000DM001 reliability experience ?
Seems like the only option I can easily get for 2TB that is on the HCL for my NV+ is this drive. I note a previous topic where users were experimenting with and starting to use this drive in their NAS...
mdgm-ntgr
Aug 14, 2014NETGEAR Employee Retired
I would also note that your NV+ warranty (3 years) has expired which limits the amount of support available anyway.
If you can't find a decent disk on the compatibility list for a legacy device, but still make a good choice e.g. a NAS drive or an enterprise drive, then in some cases we may still be able to help but it does depend on the issue.
Regardless of what drive you choose and whether or not you open a support case for issues you can seek help here on the forums.
Also regardless of your drive choice if you store important data primarily on your NAS you should backup your data. Don't trust your precious data to just one device.
