Laserbait
Jun 08, 2017Luminary
ST4000DM005 not on the HCL
Why is the ST4000DM005 not on the HCL yet? Has it proven to be incompatible?
Jun 08, 2017Guru - Experienced User
Likely it's not a priority, since it's just an updated ST4000DM000. Though I'd choose an Ironwolf 4 TB over the DM.
- LaserbaitJun 08, 2017Luminary
You're probably right, but when I see Netgear doing this with other disks: "This disk should be compatible based on the test result of another disk in the same series from the disk manufacturer." it makes me wonder.
