holsen1
Jul 29, 2019Aspirant
Straight Upgrade From ReadyNAS NV+ ?
Well My ReadyNAS finally Blew. It wont power up so I'm assuming its a PSU Failure but here's my question. I've 4 x 2TB drives in there and as opposed to Jerry Rigging a PSU to fire it up and migrat...
- Jul 29, 2019
The only drop-in replacement capability is from another NAS of the same model, which would likely be as old as yours, if not older. Take a look at what I just told another user asking a similar question: DATA-FROM-FAULTY-NAS
Sandshark
Jul 29, 2019Sensei
holsen1
Aug 03, 2019Aspirant
I found a new PSU, and put it in and the old girl fired right up, but now my cooling fan is spinning so fast its putting out a a high pitched whine I can hear 3 rooms away. The Old PSU was 95 Watts, the new one is 350 Watts. Could that be the cause. DO you know if there is a setting somewhere to dial back the fan?
Thanks
- SandsharkAug 04, 2019Sensei
The rated wattage of the power supply makes no difference as long as it is at least as high as the original . The unit will draw what it needs and no more.
Does you replacment supply have the small attached fan? If so, that's your culpret. The small size makes for a high-pitched whine. If that's not it, then you need to do a fan calibration. It's been a while since I used a RAIDiator 4.x based system, but it's in the menu somewhere.
The original NV had the small power-supply fan, and Infrant (later acquired by Netgear) replaced it with the fanless one because of complaints on the whine.
- holsen1Aug 04, 2019Aspirant
Hey, that makes sense. Yes, I believe a removed a fanless PSU and I think the new PSU has a fan in it. Honestly, I cant remember, I more looked at the wattage and the fittment. I've done a recalibration of the fan it did nothing to slow down the fan so it must be the PSU. Thank!
