leonid32
Nov 19, 2017Tutor
R7000 goes straight to http://192.168.1.1/MNU_access_setRecovery_index.htm
Hi!
My Nighthawk R7000 suddently started to go to http://192.168.1.1/MNU_access_setRecovery_index.htm every time I try to access it from any computer, connected to it - WiFi or wired.
Even if I explicitly write http://192.168.1.1/ or http://192.168.1.1/start.htm , it still goes to recovery.
I tried to pass through the recovery steps, and got the (correct) password, same as I used before. But after pressing login, I got back to the same recovery page.
I tried to clear browser cache and cookies, to no avail either. The weirdest thing is that I *can* login and get access to everything from my Android phone (using Chrome there) and even can use Android "NetGear" Genie application with no problem. So strictly speaking I have a way to do necessary stuff.
However, it would really be nice to restore access from computers as well. Anybody has/had similar experience?
Thanks!
Hi leonid32,
Try to reset the router to factory default.
- JamesGLNETGEAR Employee Retired
Hi leonid32,
Hi leonid32,
We’d greatly appreciate hearing your feedback letting us know if you need further assistance.
- leonid32Tutor
Sorry for the long delay, I was away from home for a while.
Yes, factory reset did resolve the problem; however, I feel that I cannot rely on R7000, so I purchased 2-point Google WiFi mesh, and installed it. It seems to give a better signal and is more stable.
