dtsui
Jun 30, 2012Aspirant
Stuck Disk Tray on ReadyNAS Duo
I need to upgrade my hard disks on my ReadyNAS Duo but the disk tray latch could not be released by pressing the button possibly due to accumulation of much dust and fluff, the button simply could not...
rccoleman
My advice is to try harder at the first approach :). I like to use a pushpin because it's long enough and it's easier to apply pressure with the plastic handle. Try various holes toward the right of the tray, stick the pin in the hole and apply downward pressure. Eventually it'll go.
Then I recommend working the latch over and over to wear down the plastic piece that's causing the stiffness.
