nhasenoehrl's avatar
nhasenoehrl
Succesfully changed HDD, but what else to expect?
Hello everyone,  I have been running a ReadyNAS 104 since July 2015, very successfully. Now, for the first time, I received a warning that one of my four 6TB disks had an increased failure rate. So ...
  • StephenB's avatar
    Mar 26, 2022
    nhasenoehrl wrote:
    What else is going to fail? I am really not an expert, but this thing apparently has some kind of motherboard, and it has a network card. It may have a RAID controller.
    So, I wonder, in a seven year old system, are those components likely to fail anytime soon? And if so, are my data safe? Can those components be exchanged, or is it time to buy a whole new NAS?
    RAID isn't enough to keep your data safe (no matter how new your NAS is).  The best way to keep it safe is to have at least one backup on another device.  So my first advice is to do that.  Many folks use USB drives for backup - my own approach is to back up to another NAS.
    As far as components go, the electronics in the RN104 are not generally repairable - the components are all soldered onto the system board (and Netgear doesn't see replacement system boards).  You can directly migrate your disks to any other ReadyNAS running OS 6 firmware w/o data loss - there are quite a few models.
    Based on posts here (and my own experience), disks are the most likely component to fail,  The power supply would be next.  You can find replacements for the external power bricks.
ProSupport for Business
