reaves42
Nov 02, 2022Guide
Successful Unraid installation on RN312
With Netgear dropping the ReadyNas line and lack of any support from third party apps, I was recently looking at replacements and most likely going to buy a Synology Nas. After seeing an LTT vide...
lxr200
Nov 06, 2022Tutor
I wouldn't mind speaking with you a little more about this, They might be a bit different, but I have a ReadyNAS 516 I'm throwing a Xeon processor in as well as upgrading to the 16gb of ECC memory. I've been thinking about doing Unraid, but I can't figure out how to bypass the internal boot stuff. I was able to get Windows loaded on it once.. but everytime it reboots, all the BIOS settings revert to factory and try to load up to OS 6. Were you able to figure a way around that? I removed the internal USB from the boot order, but it always goes back, and for the life of me I cannot find where that boot sector comes from, unless its a soldered on chip on the motherboard.
reaves42
Nov 06, 2022Guide
Removing the netgear usb device from boot order worked for me. If I simply rearranged the priority it kept resetting.
I did think of attempting to wipe the netgear usb from UNRAID but didnt need to try. If UNRAID didn't work, I was going to get a new NAS anyway so up to you if it's worth attempting or not.
