reaves42
Nov 02, 2022Guide
Successful Unraid installation on RN312
With Netgear dropping the ReadyNas line and lack of any support from third party apps, I was recently looking at replacements and most likely going to buy a Synology Nas. After seeing an LTT vide...
reaves42
Nov 06, 2022Guide
Removing the netgear usb device from boot order worked for me. If I simply rearranged the priority it kept resetting.
I did think of attempting to wipe the netgear usb from UNRAID but didnt need to try. If UNRAID didn't work, I was going to get a new NAS anyway so up to you if it's worth attempting or not.
lxr200
Nov 06, 2022Tutor
Got ya, Yea I went to the boot list, and removed all devices other than the HDD I wanted to use, then same with the boot order, and still, whenever the device resets, it would reset the boot order and boot list and everything.
