reaves42
Nov 02, 2022Guide
Successful Unraid installation on RN312
With Netgear dropping the ReadyNas line and lack of any support from third party apps, I was recently looking at replacements and most likely going to buy a Synology Nas. After seeing an LTT vide...
lxr200
Nov 07, 2022Tutor
Got ya, Yea I went to the boot list, and removed all devices other than the HDD I wanted to use, then same with the boot order, and still, whenever the device resets, it would reset the boot order and boot list and everything.
reaves42
Nov 07, 2022Guide
Not sure what else you can do. As mentioned I can see the Readnas usb boot drive in Unraid and thought about trying to wipe it but didn't have to resort to that.
If you are going down that route be sure to understand it may brick the device with no return path. With readyos being abandoned it seems worth a try to me. Unraid is easy to install so give it a shot and see if you want to take the chance.
- lxr200Nov 07, 2022TutorI got ya, do you have any idea where that storage is? Is it a soldered on memory chip on the motherboard? I'm just curious where the hell it is haha.
Also, when you installed unRAID, did you just install it to one of the drives that you put in the bays? Or did you install it a different way, I forgot to check if there are other sata ports on the motherboard other than the bays.
