dishmagic66
Jun 22, 2013Guide
Suggestion voor the OS6 addons
At this moment (OS 6.07) the layout of the addons is pretty anoying. Under the installed tab only really installed addons should be visible and not the addons wich are switched off and will be installed after you switch it on. This creates more chaos as it allready is.
It should be like,
Installed side: Only the really installed addons
Available side: the ones you can install.
And the installed icons should be smaller, so less scrolling is needed. The layout you see when you logon to frontview looks okay to me.
Another thing:
When the genie marketplace side is down or faulty, the installed addons on the nas are also invisible untill you touch .localapp in the correspondending folder.
No matter where the genie marketplace is, the installed stuff should be visible anytime.
For the rest, succes with bugfixing OS6. These well made Readynasses deserve good firmware.
It should be like,
Another thing:
1 Reply
- m1sterdTutorFor the RN516 at least the 6.0.8 update has changed the Apps section quite a lot, I have put a brief description in this posting: viewtopic.php?f=10&t=71090&start=15
