SJMarty's avatar
SJMarty
Suitable Fan Replacement for NV
I have an NV (purchased May, 2006) and the fan is getting noisy. The current fan is an ADDA AD0912HB-A76GL. It is rated at 0.25A at 12V DC. The specs say the airflow is 52.5 CFM at 2900 RPM. The noise level is 35 db(A). I purchased the Noctua NF-B9 due to all of the recommendations I found in the forum. Well, the fan was definitely quiet but it didn't push enough air to keep my NV cool.
I found a possible replacement...the StarTech FAN9X25TX3H. The specs on this one say the airflow is 48.4 CFM at 2600 RPM. The noise level is 33 db(A). The only spec I can't seem to locate is the amperage rating.
So, I'd love to get some feedback on the StarTech fan - from users of it or just input based on the specs. Also, if you've found something better, I'd like to hear from you too.
Thanks,
-Steve
  • SJMarty wrote:
    I have an NV (purchased May, 2006) and the fan is getting noisy. The current fan is an ADDA AD0912HB-A76GL. .... The specs say the airflow is 52.5 CFM at 2900 RPM.
    The datasheet for the AD0912HB-A76GL indicates that it's a PWM (4-wire) fan. I don't have an NV; does it have a 4-pin fan connector?
    That one is a 3-wire fan. The 4-wire version is the NF-B9 PWM. It's true that those Noctuas do not flow as much air as the original fan -- static pressure is much lower, and even in free air the Noctuas only flow about 40 CFM -- but that shouldn't matter too much unless the original fan was usually running near its max RPM. Is it possible that the Noctua failed to keep the NV cool because it wasn't the 4-wire version? (Or because it was mounted backward?)
    And... How did you determine that the NV wasn't being kept cool enough? Were the reported temperatures outside the normal range, or were they just higher than with the original fan?
    I'd be very surprised to hear that it draws more than the original fan's 250mA, so I don't think that's a concern... But it's not really quieter than the original fan (assuming that the original fan isn't making more noise than usual due to bad bearings).
  • Thanks for the reply. I should have been more clear about the issue in my original post. The increased noise in the current fan is the bearings going bad. The noise level from the the fan when it was operating normally was fine. I also must have written something down wrong regarding the model. The current one is definitely a 3-wire fan and not a PWM.
    When I installed the Noctua, it was installed the same direction as the current one. The temperatures were within the limits that are displayed in Frontview but I don't really use those as a guide. The high end of the "normal" range is 140°F. I don't recall how high they went before I shut it down but they were quite a few degrees higher than they were with the old fan. A quiet fan would be nice but I really didn't want to have my NV run hotter as a result. To me, that's just asking for trouble on a unit this old. Typically, with an ambient temperature of 78°F, my NV runs around 88°F and disk temperatures range from 87°F to 93°F. The fan runs between 1800 and 2000 RPM. It's currently running at 1829 RPM.
    I went ahead and ordered the StarTech fan and it was delivered yesterday. It is actually an Evercool brand. Model EC9225H12BA. The amperage is listed as 0.21A.
    So I'll give this one a try and see how it does.
