mas99
Aug 06, 2014Aspirant
support failure #23459989
I'm having a nightmare of time with tech support. I have an Ready NAS NV+. This unit was RMAd june 2013 over power supply. With a lot of tech support the rebuilt unit was up and running. The problem ...
mdgm-ntgr
Aug 06, 2014NETGEAR Employee Retired
Hi mas99,
I have moved your post to make it easier to follow your issue. I have also edited the thread title to include your case number.
I will pass on your case number for review.
I believe you should power off the NAS, then remove disk 2, then turn it on again normally and let us know what is showing on the LCD if it doesn't complete booting.
