aliv
Jul 31, 2018Aspirant
support for active directory integration
Hello all,
I use to ReadyNAS Ultra 6 device. (firmware version: RAIDitor 4.2.31)
I want to connect that storage devices to Active Directory.
How can I do it?
Thanks
ALi
I believe that in OS 4.2 Active Directory is limited to business class only (the ultra was considered to be a home NAS product).
When you go to security->security mode in Frontview, are you seeing a security mode called "domain"?
If not, you could get this feature by converting your NAS to run OS 6. Netgear doesn't support that setup, but quite a few folks have done this with good results.
- alivAspirant
Hi Stephen,
I agree with you, it does not support Active Directory.
But, I interest convert OS 6.
How can I do it? I dont have idea..
Thanks your support
Instructions are here: https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-OS-Upgrade-from-4-2-30-to-OS-6/m-p/1181060#M120724
This can also be reversed if you change your mind on it later.
