pearly
Nov 07, 2006Aspirant
Support for Seagate SV35 Series?
I found these drives on NewEgg.com. Any chance you guys are testing these drives?
Mr_B
Jul 16, 2012Guide
Well, seeing as most drives aren't tested, you either get the one of your size choise that has been tested, or don't get one at all, if thats what your going to go by.
Survilance / video recording aimed is simply due to being low RPM, low heat units, and nothing stops them from running just fine in RAID's. I asked Seagate support before i bought them, and they indicated that i should expect slightly lower performance then with higher end RAID aimed drives, simply due to the nature of the drive. Since there isn't any drive made in the last 15 years or so that doesn't outperform the NV+ (sparc) that wasn't really an issue...
Also, if someone was to check on my posts, they'd find that i RMA'd one of the drives for bad clusters after a few months, and Seagate didn't even twich when it was said the drive was in a RAID envirorment. They ended up shipping a new drive as a replacement, rather then a refurbished.
B!
B!
