Knowledge Base Article
New - RBK10/20/30/40/50 Series Firmware Version 2.7.6.6 Released
Release Date: January 13, 2026
Security Fixes:
This firmware addresses security vulnerabilities. For more information about security vulnerabilities, visit https://www.netgear.com/about/security
Download links :
RBK10 Series: https://www.netgear.com/support/product/rbk12
RBK20 Series: https://www.netgear.com/support/product/rbk20
RBK30 Series: https://www.netgear.com/support/product/rbk30
RBK40 Series: https://www.netgear.com/support/product/rbk40
RBK50 Series: https://www.netgear.com/support/product/rbk50
Applies to all primary and sub model series as well.
Reminder: This series of Orbi models are EoL. So these updates are only for security fixes. No feature fixes or additions will be seen. Support and End of Service FAQ | NETGEAR Communities
Firmware Update Instructions:
To update your product’s firmware, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click the Documentation button on the product page.
Please navigate to the link below for step-by-step instructions on how to update your Orbi model system: Procedure to Manually Firmware Update Orbi and Nighthawk Mesh systems. | NETGEAR Communities
Be sure to update the RBS FIRST, then the RBR lastly.
I HIGHLY recommend after the FW is loaded on the system and it's back to ready, power OFF all Orbi units and the ISP modem/ONT for 1 minute. Then back ON with the ISP modem/ONT first, then RBR then RBS.
The best advise we can give people is to start a new config, power on one RBS and wait for some SOLID light or most often blue or magenta. And then add the RBS WIRELESSLY via the WebUI. Power off the RBS. Then rinse and repeat with any additional RBS(s). Pair RBS one at a time even if you have more than one. For ethernet connected RBS, after things come up wirelessly, you can move to wired backhaul but don't start with wired backhaul for those RBS that are ethernet connected. Wirelessly connect and sync RBS first before ethernet connecting RBS.
NOTE: Orbi app or the routers web page may not report seeing new FW updates. NG may not push this to there auto update services immediately and may activate the newer FW update being seen on there auto update services at a later time. User will have the choice to manually update if you want too.
A factory reset maybe needed if problems are encountered after the FW update:
Orbi Systems Manual Factory Reset Process | NETGEAR Communities
NOTE: Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200
This article applies to:
WiFi 5 (Wireless AC)
  • RBK12
  • RBK13
  • RBK14
  • RBK15
  • RBR10
  • RBS10
  • RBK20
  • RBK20W
  • RBK22
  • RBK23
  • RBK23W
  • RBR20
  • RBS20
  • RBK30
  • RBK40
  • RBK43
  • RBR40
  • RBS40
  • RBK43S
  • RBK44
  • RBK50
  • RBK50v2
  • RBK52W
  • RBK53
  • RBK53S
  • RBK53V
  • RBK53v2
  • RBR50
  • RBR50v2
  • RBS50
  • RBS50v2
Let us know how it works for you...Please make a new post regarding any problems your seeing in the Orbi AC support forums:
Orbi Wi-Fi 5 (AC) and Orbi with Voice Mesh | NETGEAR Communities
Thank you.
Comments have been turned off for this article
