VasanthakumarP
Aug 03, 2016Aspirant
Surveliliance App ReadyNAS 516
Hi When i install the ReadyNAS Surveliance app in ReadyNAS 516 model .it take more time downlaod the suveliance app ,it didn't complete the installation .past two days we were working on it. any...
mdgm-ntgr
Aug 03, 2016NETGEAR Employee Retired
Which firmware are you running?
Have you installed any other apps recently?
VasanthakumarP
We are running the latest firmware version 6.5.1.
yes , we are not install any app recently.
- mdgm-ntgrAug 04, 2016NETGEAR Employee Retired
Is a static I.P. address set on the NAS?
If so, can you check to make sure the DNS Servers are specified correctly. Perhaps also try Google DNS (i.e. 8.8.8.8)
