lwilliamson
Mar 24, 2016Tutor
Swapping Network Card - 10GbE for CX4
I have a ReadyNAS 4220 that came with a dual port 10 Gigabit Ethernet card, I need to replace it with the CX4 add-on card. I've replaced the card, but I am not seeing the ports in ifconfig nor the f...
- Mar 24, 2016The card ended up being bad, I swapped it and after updating to 6.4.2 the new one was recognized immediately.
lwilliamson
Mar 24, 2016Tutor
So I found this archive of GPL sources:
http://www.downloads.netgear.com/files/GPL/ReadyNASOS-V6.2.2_WW_src.zip
It was a pain to download, I think there are some server issues in play.
I will update as I go.
