lwilliamson
Mar 24, 2016Tutor
Swapping Network Card - 10GbE for CX4
I have a ReadyNAS 4220 that came with a dual port 10 Gigabit Ethernet card, I need to replace it with the CX4 add-on card. I've replaced the card, but I am not seeing the ports in ifconfig nor the f...
- Mar 24, 2016The card ended up being bad, I swapped it and after updating to 6.4.2 the new one was recognized immediately.
lwilliamson
Mar 24, 2016Tutor
- mdgm-ntgrMar 24, 2016NETGEAR Employee Retired
There was a major kernel upgrade in 6.4 so it could be the network drivers for that work with a wider range of hardware. Note that if you use your NAS with an unsupported hardware configuration you may run into issues.
