tony359
May 09, 2014Apprentice
Switch advice please
Hello, Having verified that my Virgin Media 'Super Hub' is not the best as a switch, I was thinking of getting a decent one which I may use for some years when/if my network expands. I like the ide...
xeltros
May 10, 2014Apprentice
Cisco definitely have bonding support, it's called Etherchannel (see http://www.cisco.com/c/en/us/td/docs/sw ... thchl.html) and can add up to 8 links. That said, I don't know if every switch/router they made has that or if this is just for pro devices with console access, I believe office switches are the cheapest one with web interface and stripped down OS.
I personally have a D-Link DGS-108 which works like a charm, it's as silent as it can get and has no problem giving me full gigabit speed. That's the important thing to check whether or not the switch can provide full speed (which requires (1Gbit/s up + 1Gbit/s down)*number of ports, so 16Gbit/s for a 8 ports switch). It's not manageable but I don't require it to be and unless you want VLAN I don't see why you would need it to be. My NAS has NIC bonding but :
1°) it isn't fast enough to get full Gbit speed
2°) I would have to get several gbit devices to get data from it at the same time
3°) I'm unsure if the switch needs to have a specific setup to make this work, I thought the OS had a trick for that.
After that you have to know which system you want to use, I was certified on Cisco devices, so I guess the simplest for me is to stick with Cisco rather than Netgear or Juniper. Although nowadays they have web interfaces for lower end devices.
