GL1zdA
Feb 18, 2016Guide
Sync to USB drive instead of clear and full backup
Is there a way to sync a folder on the ReadyNAS to an USB drive instead of having it cleared and fully backuped? I have a large share on the NAS and a 2 TB USB drive attached. On this share new files...
- Feb 26, 2016
local rsync backup would be a good feature. I suggest posting it in the idea exchange ( https://community.netgear.com/t5/Idea-Exchange-for-ReadyNAS/idb-p/idea-exchange-for-storage?topic-zoom=&sort-by=&date-range=all )
Bruce_In_Philly
Mar 11, 2016Aspirant
Sync instead of backup to USB
Rsync to a USB attached drive instructions are here:
Check Pixel81 instructions. They work. I could not get the input to accept "FILES & FOLDERS TO BE EXCLUDED:
- Select the ‘+’, enter the following in the “Name:” text box, select ‘Apply’:
/data/._share" But other than that , it works for me. Way Way better than the backup feature... I just wanted a sync'd USB drive, formatted NTFS so I can remove the drive and plug into any machine.
Peace
Bruce in Philly
GL1zdA
Mar 12, 2016Guide
That's what I did, but it was painfully slow. Apparently, rsync works different when working over the network and locally and doing it using "localhost" as a target causes to much overhead.
- StephenBMar 12, 2016Guru - Experienced User
Possibly, though rsync uses a lot of CPU resources, and it might have been slow locally too.
Either way, a lot of users want to use rsync locally to USB, and the localhost work-around is clumbsy.
