Ray2
May 16, 2025Luminary
Synchronize clock with internet server not
ReadyNAS 314 running firmware 6.10.8. This is one of two ReadyNAS's on my small network. Noticed the time on the 314 was ahead exactly two hours. Inexplicable since other ReadyNAS showing pr...
Ray2
May 17, 2025Luminary
To saudade---I have tried many different time servers including time.nist.gov---to no avail----you're missing the point---it will NOT accept ANY time server---it simply spins a bit then blanks it out.
To Sandshark---THAT was my first thought too---but NOT true---it was set properly. And again---now that I turned it to manual and set it properly---I can't get the AUTO set feature to accept ANY time server---and least we all forget---meanwhile my other NAS works as always behind the same router---and in any event I checked the router time settings and firmware to see all okay there--and it is.
May 17, 2025Guru - Experienced User
Ray2 wrote:To saudade---I have tried many different time servers including time.nist.gov---to no avail----you're missing the point---it will NOT accept ANY time server---it simply spins a bit then blanks it out.
FWIW, 0.us.pool.ntp.org is working on all my NAS.
Did you try rebooting?
Is there anything useful in the log zip file?
