Murriteacher
Mar 04, 2017Follower
Syncing readyNAS 104
I have done a factory reset as my cat pulled the power cable out of the unit. Lost all data! No real problem as I have numerious backups using different media. The system has 4 X 4Tb drives but the sync tells me there is 77,000 plus hours to complete. I think I should have re formatted the disks. This is NOT a critical system and was purchased to give me the oportunity to learn about NAS. I will be trying different brands of HDD's and later try some SSD's to see what happens. Main problem today is WHAT is causing such an extended sync time?
1 Reply
- mdgm-ntgrNETGEAR Employee Retired
Support could have had a look into that problem before you did the factory reset but there would have been some fees involved. Glad you had a backup.
Have you checked the SMART stats to check for clues of a bad disk?The initial estimate for how long a sync will take can be a massive overestimate of how long it will take. Is it still showing such a huge amount of time to complete?
Using SSDs would make more sense in a more powerful NAS unit. The RN104 is a cost effective model.
