oorgg
Oct 07, 2012Aspirant
Synology DS212j VS Netgear ReadyNAS Ultra 2 RNDU2000
Hi, I am thinking about buying ether a Synology DS212j or a Netgear ReadyNAS Ultra 2 RNDU2000. I currently leaning towards the Synology due to the Netgears non standard file system. Could anyone p...
mdgm-ntgr
Oct 07, 2012NETGEAR Employee Retired
No ReadyNAS uses proprietary RAID. The filesystem used is not proprietary. Data recovery is possible using a PC especially one running Linux. What is proprietary is the expansion scripts used to automatically expand volumes.
For the Ultra 2, in a Linux PC, You would use mdadm to start the RAID, scan for volumes and then mount them. If you don't have the necessary packages installed they could easily be installed using apt-get.
Having said that most users would consider moving arrays from one ReadyNAS to another on the same platform to be easier. Also remember the ReadyNAS Ultra Series has a 3 year warranty.
