dtsaoboy
Jun 20, 2020Aspirant
System volume root's usage is 94%
Only after upgrading to the recent firmware did I get this message. I 'm a novice, so I would love some help to sort out what I need to do to fix this issue. I do not see this warning in my log for s...
JohnCM_S
Jun 20, 2020NETGEAR Employee Retired
Hi dtsaoboy,
The OS partition is almost full which is why you get that message. Do you have any third-party apps installed on your ReadyNAS?
It will be best for you to contact NETGEAR Support so they can assist you in freeing up space on the OS partition.
If SSH is enabled on the NAS and if you are comfortable in accessing it via SSH, you can access it that way to investigate it further. You may seek advice from the other Community members when you decide to go to that route.
