dtsaoboy
Jun 20, 2020Aspirant
System volume root's usage is 94%
Only after upgrading to the recent firmware did I get this message. I 'm a novice, so I would love some help to sort out what I need to do to fix this issue. I do not see this warning in my log for s...
JohnCM_S
Jun 23, 2020NETGEAR Employee Retired
Hi dtsaoboy,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as a solution so others can be confident in benefiting from the solution.
The NETGEAR community looks forward to hearing from you and being a helpful resource in the future!
- dtsaoboyJun 23, 2020Aspirant
Hi,
Thanks for following up. Because I am not comfortable going to the system partition drives to delete files, I paid for the prosupport and requested help.However, they think it has something to do with a bad hard drive, that was slowly failing. I think it is an unrelated issue, but they dont think so. So, I am in the process of replacing both drives as we speak. Once that is done I will see if I get the same message. However, in the process of completing the sync of the backup drive, I got the same message this morning. I am now syncing the first drive so will know soon. If prosupport cannot help, I will need some stepwise instructions on how to do this myself.
Thanks
- SandsharkJun 25, 2020Sensei
You will get the same message unless they did something more. I am not familiar with anything that bad drives would do to cause the OS partition to fill. The resulting logs just wouldn't normally be big enough. But perhaps they have identified something there that did it. But replacing the drives will just copy what's on all partitions to the new ones, it won't reduce the size of whatever is taking up the space, nor will it increase the size of the OS partition. I find it strange that they did not at least partly clean up the OS partition before having you take this action. Are you sure they didn't?
- JohnCM_SJun 25, 2020NETGEAR Employee Retired
Hi dtsaoboy,
I agree with Sandshark that you will just get the same message even after replacing the bad drive.
It appears that the issue is already resolved upon checking the case. It was escalated to L3 and found out that ClamAV filled up the OS partition.
- dtsaoboyJun 25, 2020Aspirant
Hi John,
Thanks for following up. You are correct, replacing the bad drives with new ones did not solve the OS system volume issue. This was initially recommended, although reasonable concern, was not the original problem. Yes, because I didnt want to mess anything up, I asked that tech support help me solve the issue. For me, could you explain what ClamAv process is? Also, I havent tried to enable the antivirus anymore and not even sure it will work. Is the recommendation not to use it? or has it been permanently disabled?
Thanks,
Dave
