choddo
Aug 30, 2011Aspirant
Taking a punt on the WD20EARX SATA3 disks
These aren't in the HCL but the SATA2 version seems to be disappearing fast (and the sub-product code on the HCL seems to be gone already) so what the hell. Assuming these disks do work (can't find...
xenophon1
Sep 01, 2011Aspirant
Just a quick question - some drives already IN the HCL have 4K sectors, and I'm not talking about the problematic WD models that require a factory default. What about those (i.e. not the WD ones)?
I'm asking because my ReadyNAS Pro lists a 4096 block size in its volume log (thanks for the tip, BTW), as it was initialized with Radiator 3.x. Can I put a, say, Seagate 2Tb drive with 4K sectors WITHOUT resetting the NAS? My objective is to autoexpand, if possible, from 6x1Tb to 6x2Tb.
With greetings from Athens.
Xen
Xen
