choddo
Aug 30, 2011Aspirant
Taking a punt on the WD20EARX SATA3 disks
These aren't in the HCL but the SATA2 version seems to be disappearing fast (and the sub-product code on the HCL seems to be gone already) so what the hell. Assuming these disks do work (can't find...
choddo
Sep 02, 2011Aspirant
Well the disks seem to work fine. I don't yet know if they will exhibit the power saving parking issue. Will keep an eye on the LCC.
After recreating the C volume and rebooting, the third disk started to sync (4th is in my PC as the NAS backup holding pen) and that's going to take about 24 hours. Which seems a lot for an empty volume but I guess writing the parity data isn't a simple 1.8TBs of zeroes (or perhaps it is, but those zeroes have to be written & verified)
Seems happy enough with me copying the data back at the same time, albeit that's only writing at about 13MB/s
Thanks for the advice, all seems to be going to plan.
