Stuuk1
Feb 24, 2014Aspirant
Tapatalk Login Issues - Admin, please respond..
Hi Admin,
I had a few issues logging in when I signed up, I now need to login with a CAPTCHA each time. While this isn't a problem on a browser, I cannot do this through Tapatalk.
Could you please reset my account or whatever is needed so that I no longer require to use a CAPTCHA?
Thanks in advance
Thanks in advance
- mdgm-ntgrNETGEAR Employee RetiredMaybe a bug that could be fixed by updating the Tapatalk plugin on this forum to the latest version. I haven't looked at the Release Notes (if there are any) so I don't know if there is a fix in it or not: http://tapatalk.com/activate_tapatalk.php?plugin=phpbb
Edit: Are you saying you are getting the CAPTCHA each time you go to login even via a browser? You shouldn't get that till after a failed login attempt normally. If that is the problem I could try forcing your account to reactivate (would need to click on a link in a new email that would be sent to your address) to see if that helps. - Stuuk1AspirantHi, thanks for your reply.
Yes, every time I log in, even on a browser I have to enter a CAPTCHA.
I'll try anything you think will work, so go for it..!
Thanks for your help. - mdgm-ntgrNETGEAR Employee RetiredI haven't tried that yet but I'm informed the problem should be fixed now. Can you check?
- Stuuk1AspirantAll fixed, thank you so much!
