alltet
Sep 24, 2012Aspirant
Thermaltake Blacx 5g Duet
Hi. I can see that the Blacx 5g is in the compatibility list, how bout the Duet? planing on adding support for any multi disc dock? When connecting the 5g duet to my Readynas Ultra 2 USB3 port only one disc is visible. Probably not to hard to fix, and great when upgrading the internal discs to be able to reuse both the old ones.
1 Reply
- alltetAspirantSince its a bit random on boot which drive i mounted on the dock i guess that the driver already supports the dock but the OS just needs some code to understand that there is 2 drives mounted on the same usb port.
