Shadow1980
Aug 23, 2011Aspirant
Thinking of Upgrading from ReadyNAS Duo - Best options?
I currently own a ReadyNAS Duo with 2x 1.5TB drives. (~1.3TB of usuable space) The only real change I made was upgrading the RAM to 1GB, as it was a cheap upgrade at the time and came highly recommen...
mdgm-ntgr
Aug 23, 2011NETGEAR Employee Retired
You could use the Duo to backup your most important data from your new main NAS.
I'd recommend dual-redundancy on your new NAS. The use of an additional disk's capacity for redundancy is great for peace of mind. Whilst it doesn't replace the need for backups, it does strengthen your first line of defence
