Shadow1980
Aug 23, 2011Aspirant
Thinking of Upgrading from ReadyNAS Duo - Best options?
I currently own a ReadyNAS Duo with 2x 1.5TB drives. (~1.3TB of usuable space) The only real change I made was upgrading the RAM to 1GB, as it was a cheap upgrade at the time and came highly recommen...
Shadow1980
Aug 28, 2011Aspirant
Both are up and running - currently using rsync to get the files from the Duo to the new Ultra, which is going to take up to wednesday at this rate.
After that I will setup the DUO as a backup NAS, and rsync the most important shares it.
Now the real trick will be to set-up an iSCSI share and map My Documents to it, so they are always on the Ultra, with the DUO backing them up constantly. That would give me a lot of peace of mind... (I'm not sure about the best way to go about this though!)
