Shadow1980
Aug 23, 2011Aspirant
Thinking of Upgrading from ReadyNAS Duo - Best options?
I currently own a ReadyNAS Duo with 2x 1.5TB drives. (~1.3TB of usuable space) The only real change I made was upgrading the RAM to 1GB, as it was a cheap upgrade at the time and came highly recommen...
mdgm-ntgr
Aug 28, 2011NETGEAR Employee Retired
You could create an iSCSI target on the Duo too (there is a community add-on: http://www.readynas.com/forum/viewtopic.php?f=47&t=34170), mount a target on that and use Windows software to replicate your My Documents folder onto the Duo.
