amarschilok
Mar 28, 2019Aspirant
Throughput/ File Transfer speed issues
My hardware:
Netgear ReadyNAS 102, running FW v6.9.5
2x WD20EFRX-68EUZNO (2 TB each, Western Digital Red) HDDs in RAID 1
Netgear GS105v5 switch
HP Elitebook with fresh, clean install of Win 1...
Hopchen
Mar 28, 2019Prodigy
Hi amarschilok
Yes, the RN102 and RN104 are quite underpowered. That being said, 15-20 MB/s is quite low even for those units.
I recommend that you read the excellent guide that Retired_Member made. Link below.
It contains some good tips and tweaks on how to improve performance and stability of RN100 series.
Cheers
Hopchen
Mar 28, 2019Prodigy
Also, since you are in with SSH already, what speeds do you get with a dd test?
cd into one of your shares and:
dd if=/dev/zero of=file.bin bs=4M count=250
