amarschilok
Mar 28, 2019Aspirant
Throughput/ File Transfer speed issues
My hardware:
Netgear ReadyNAS 102, running FW v6.9.5
2x WD20EFRX-68EUZNO (2 TB each, Western Digital Red) HDDs in RAID 1
Netgear GS105v5 switch
HP Elitebook with fresh, clean install of Win 1...
Mar 29, 2019Guru - Experienced User
amarschilok wrote:
BASH keeps telling me "permission denied" when I try to run "apt-get update" and "apt-get install iperf". How do I get root permission to the unit to install iperf to do testing?
You log in as root, and use your ReadyNAS admin password. Generally it's a bad idea to log in as admin.
Have you disabled AntiVirus?
Also, disabling strict sync on your shares will increase speeds.
