takoma
Aug 19, 2012Aspirant
Time to upgrade - could use some input
Hello. I'm running two ReadyNAS NV+ devices. The primary needs are for storage of PC computer backups, primary storage of media libraries (lightroom photos, iTunes music) and for time capsule back...
Aug 21, 2012Guru - Experienced User
I picked up one myself, they look to me like a good choice as well. They are getting good early reviews, but of course they are brand new drives - so there is some risk that something will turn up later. However if you are looking for a consumer-grade drive, the WD RED drives are the best option from WD.
takoma wrote: Thanks to all. Put in an order for a pair of Ultra 4+ with the rebate at Frys.
Now for the drives, I'm thinking of starting with 3 of the 3TB WD30EFRX drives. They look to be a good middle road that has the larger cache and Rotational Vibration Safeguard at a reasonable cost.
Any reason not to go with these?
