Ematheu
Mar 25, 2021Aspirant
TIVO Bolt don't see NAS-312
TiVo Bolt not longer see the NAS-312 I start having the problem a week ago or litle more, my Tivos Bolt don't see my NAS-312, I reset the tivos, I change ip address, I reset router, switc...
Ematheu
Thank you for your idea, but my version is 6.10.4, I really don't notice where it is missing the connection with the tivo since I had the NAS off for few days, like 5 or 6 days, regarding PLEX I saw it charge 4.99, I really don't want to pay for that when I can stream directly from my NAS
(before I have this problem) and like I say in my post I check everythiing in the NAS also in the settings I saw my two tivos say Ready, but they still not showing in the Tivos, also I dissabled and enabled the Moca + Ethernet on the tivos, and still not showing. reallaay don't know what to do now, I'm afraid to loose my data in the HHD moving firmware back and forward, I really apreciate any help
Thanks
Sandshark
Mar 25, 2021Sensei
The advice I gave regarding reverting to old versions applies no matter what version you are runing. You can revert from 6.10.4 to 6.10.0 but no further.
Do you know what protocol the Bolt uses if not Plex? I think you need Plex to offload saved programs to the NAS, but I guess there are oither optins for just viewing files.
I do see some messages on various boards about issues with a Tivo update a couple days ago, so you should take a look at some of those, too.
- EmatheuMar 25, 2021Aspirant
I never used Plex all ways used directly from NAS to the tivo, and I upload to the NAS from my computer, I call support and they say to fill a form online and phone hang up, really start dissapointed with netgear, ok, where can I get old firmwares like 6.10.0 ? hope this help netgear really dont giving any support on the phone! and I think I'm not the only one with this problem, I bid anything that many of the people are looking at this are having issues too. thanks for your help really appreciate
ok can I downgrade from 6.10.4 to 6.10.0 and don't have a data lost ?
Thanks
- StephenBMar 25, 2021Guru - Experienced User
Yes.
I don't own a Tivo, so I don't know how you did that exactly.
There is a Plex client on the TiVo, so this might have been using the Plex server on the NAS. You shouldn't need a subscription for a local plex server unless you are streaming to a plex mobile app (or using one of the other paid options). https://support.plex.tv/articles/202526943-plex-free-vs-paid/
The NAS also has a built-in DLNA service, and it includes a TiVo server option. So maybe check system->settings->services->DLNA to make sure that service is enabled, and that the TiVo server option is turned on.
Thanks for your help, yes Tivo was able to stream direct from the NAS-312 (not previous versions) I have my NAS, tivos and TV in the same network segment, and I stream directly to my TV through the Tivo, my TV actually see the NAS-312 so I think I have not other option to stream
direct to my TV instead than use the Tivo like before, but what piss M...O.... is that this Co. make firmwares that mess up us. and they start blaming each other, Tivo say is Netgear, Netgear say is Tivo, and soo on, the problrem I think will be when I try to install an old firmware the
NAS will going to say a new firmware is installed and not take the old one, ans I don't want to lost all my movies all ready in the NAS, Netgear is not providing anything that help, and I see a lots of people look and not help, I think probably if they see an accidented person in the floor they will do the same, look at the person and continue the walk, unfortunately is like that just couple peoples allways try to help. thanks again. I browse the nas folder in my computer and I drag the file I need to move to my nass and it copy perfectly, I did that with all my movies.
