Ematheu
Mar 25, 2021Aspirant
TIVO Bolt don't see NAS-312
TiVo Bolt not longer see the NAS-312 I start having the problem a week ago or litle more, my Tivos Bolt don't see my NAS-312, I reset the tivos, I change ip address, I reset router, switc...
Ematheu
Do you saw the picture I send with the ReadyDLNA settings? thanks
Mar 26, 2021Guru - Experienced User
Yes. Note embedded images need to be reviewed (manually) before they are shown. That's why you saw the triangle when you first posted it - it was in the queue for review.
Your most recent screenshot shows that the NAS is finding two Tivos (living room and master bedroom). Though that screen is more about archiving. You might look in the archive folder on the NAS, and check if the archiving is still happening.
I am still confused about whether you had Plex installed on the NAS - and if you did, when you uninstalled it.
Also, I am still wanting to know if you have DLNA enabled for your media shares. It's not enough to enable it in system->settings. As a reminder, that is controlled via the share settings wheel for the various shares.
- EmatheuMar 26, 2021Aspirant
OK I solve the problem, and I know iit is a FIRMWARE problem, since I downloaded the Firmware 6.10.0 and I installed in the nas, I reboot NAS and TIVO and BANG! NAS start showing in my TIVO, and like the guy say before that I need PLEX for streaming my movies from NAS, NOT I don't need PLEX I just click NAS-312 and I can see all my movies there and stream it, here is a screen picture from my TV showing the NAS in the TIVO,
- StephenBMar 26, 2021Guru - Experienced User
JohnCM_S , Marc_V : Can you make sure this bug is logged in your systems? It clearly is a regression. I don't think it makes sense for anyone to have to pay in order to get this on the bug list.
StephenB wrote:
Ematheu wrote:I downloaded the Firmware 6.10.0 and I installed in the suspiction, I reboot NAS and TIVO and BANG! NAS start showing in my TIVO,
I just delete the logs, but I don't saw anything that can give me an idea where the problem was, but one thing is for sure, after 6.10.0 is a bug that don't let the NAS-312 show up
in the TiVo recorded shows (I don't try 6.10.3 I don't want take the risk to lost again the NAS, so I will stay in 6.10.0 and not going to do any futures update till Netgear fix this issue, they tyrn the head and ignore it) I really waant someone from Netgear take a look to my post, I saw on google few peoples complaining about this, some one heree told me to use PLEX, I DON'T LIKE PLEX and I don't want my personal collection is in other server when I don't know if they take a copy of everrything, I stream direct from my NAS-312 and I'm very happy that way.
NETGEAR NEED TO TAKE A LOOK AND FIX THE FIRMWARE HERE ARE CLEAR EVIDENCE.
