RA-s's avatar
RA-s
Tivo bolt is not working with my readynas 212
Hello everyone
I am new to ReadyNAS and i ve been trying to figure out stuff but its not working. Tried calling customer service as well but so far theyre not able to help out either.
I was recommended to get a readynas from tivo tech support(whom i dont seem to find anymore) and was told that my shows can be stored in the readynas and can be accessed later.
I was able to setup the tivo bolt in my readynas settings, going into the readydlna and adding the media key where it is able to see my tivo. I schedualed the recordings to be downloaded and
it started downloading two shows , as i could see their folders when i went into browse . Now the problem number one is that its not recording any more shows and i dont see that i have designated any limits to the amount of shows. Secondly even though i still see my tivo in readynas settings but i dont see my readynas in my tivo bolt anywhere. Not in the my shows, no where. I have tried searching the internet but not coming across a straight answer. Please help me out. I am trying for tivo to store shows in my readynas 212 and and i would like to access and watch them through tivo bolt.
my setup is I have a tivo bolt connected through LAN to my Netgear router R8500, my ReadyNAS 212 is connected with two aggregated LAN ports to the router.
Please help me out.
Thanks
1 Reply
  • BrianL2's avatar
    BrianL2
    NETGEAR Employee Retired
    Hi RA-s,
    Which Firmware is running in your ReadyNAS system? Have you tried to re-enable the TiVo Server feature, add your TiVo device and assign a directory or path.
    Looking forward to your response.
    Kind regards,
    BrianL
    NETGEAR Community Team
ProSupport for Business
