Kimera
Jul 21, 2014Guide
Toshiba DT01ACA series HCL: some data should be corrected.
Checking the ReadyNAS HCL - HDDs in order to deploy a ReadyNAS 104 or a ReadyNAS 314 with Toshiba rotational disks I noticed that Toshiba DT01ACA series is reported with incorrect data and it should, ...
Kimera
Nov 20, 2014Guide
After four months (see above) wrong data is still displayed on the ReadyNAS HCL about those rotational Toshiba disks...why nobody care to check that and then correct/update as necessary?
