Stultis
Dec 01, 2018Aspirant
Trouble setting up FTP on ReadyNAS 102 with Linksys router EA6900
Hello, I am having trouble setting up my ReadyNAS for FTP. I have a Linksys router (EA6900) I am using for WIFI. I have the FTP enabled on the ReadyNAS and can see and use the FTP settings around my ...
Dec 06, 2018Guru - Experienced User
Did the IP address of the PC change when you switched to the new router?
Stultis
Dec 06, 2018Aspirant
Yes. I went through all of the backups and changed them to the new ip address.
The funny thing is it ran most of the backups until that one. It keeps saying “unable to make folder #.” I have a folder named # in that folder, but I have a folder # in the other folders that successfully backed up. These folders are in a share like My Comics/Small Industry( or Marvel or Dark Horse... etc)/(# or A-Z) the # is for comics with a title starting with a number or symbol the other folders are for titles of comcis beginning with A-Z. I scan the comics I buy into my computer so I can read them on the go, or just reread them without having to get the physical copy out of storage. I have the harddrive the comics are on named My Comics and have multiple folders of the different companies. Inside of the individual company folders are folders named #, A-Z. This hard drive is set as a share and set to show up in my library like the pictures, documents, videos,... etc. I have another hard drive with my family photos on it that backs up to the NAS , set up the same way as the comics hd, and it worked. I have not tried to backup my itunes folder on the main hd.
I guess I should go back and check the small companies folder and make sure the share permission did not change. I might do that tonight, to rule that out as the problem.
- StephenBDec 06, 2018Guru - Experienced User
Also see if there is a shortcut in the PC source folder.
- StultisDec 06, 2018Aspirant
Just checked all the shares and permissions, they are the same for all the folders. I did not see a shortcut in the folders. I did notice that the folders are all read only. I'm not sure if that will make a difference. I tried changing this to test if that was the problem. The folder would say it was being changed from read only, but would stay read only. Is this because of the folder being tied into my Libraries? I am running Windows 7. The folders that did backup to the NAS are also read only.
I just tried to run the backup again and it failed again. It gave me this as the failure message.
This has me stumped. I might try to create the folders on the ReadyNAS and then try backing up from there. I did not have to do that with the other Backups. They completed and I had changed the "sub-folders" names on my pc. I have the backups set to delete all information in the folders connected to the backup before backing up. I did this because I did not want the NAS to become crowded with the same files in different locations if I moved or deleted the file.
- StephenBDec 07, 2018Guru - Experienced User
Stultis wrote:
I did notice that the folders are all read only. ... The folder would say it was being changed from read only, but would stay read only. Is this because of the folder being tied into my Libraries? ... The folders that did backup to the NAS are also read only.
I think that's just how Windows reports attributes (which is confusing).
Are any files being copied by the backup job? If none are, then I suggest creating a test share on the NAS with default file permissions, and try retargeting the backup destination to the test share.
Perhaps also try a drag-and-drop from the Windows PC to the NAS backup folder, and see if that works.
- StultisDec 07, 2018Aspirant
Hello,
None of the files were being backed up by that backup job. I tried creating a new backup job that only targeted the 001 folder. I then added a 001 folder on the nas in the destination folder. When I ran the backup job it completed the backup without a problem. I am going to do the same with all of the folders under that old backup job.
I’ll also double check my permissions on the nas for all of the folders. They should all have me as having permission to read/write. Then have read only permissions for my relatives on certain shares like family photos. Other folders are hidden from their view.
My general approach for permissions is to rely on the network permissions to manage access, and leave the file permissions as full read/write for everyone. That won't work if you want to control permissions for specific subfolders, but if you don't have too many of those you can make them independent shares.
- StultisDec 08, 2018Aspirant
That’s how I’ve got it set up, except for the read/write privelages. I’m letting them download but not upload.
I found out why the system kept crashing when I would try to backup that folder. Some of the files in that folder are rather large and seem to give the system trouble. I can’t get the system to let me delete those large files from the nas. Everytime I try it freezes. Freeze might not be the right term, I can work on the system just not in the folders. The backups stop working and it doesn’t show what apps I have running. I can tell the system to reboot or shutdown, that’s about it. I do have the antivirus running and have the system setup for a traditional raid format. The nas has two 6TB wd red hardrives in it.
I’m wondering if I would be better off getting a large external harddrive and plugging it into the router to use like my nas, then set up the ftp with privaleges for my relatives using the external harddrive. I can then use the harddrives from the nas in my pc to backup the information I want copies of and get rid of the nas. I have had a little trouble with it on occasion acting squirrelly, just never like this. The only downfall is if the pc is destroyed I lose those harddrives, but get to keep the external that is connected to the router.
I forgot to say I have had the nas system for 4 years now.
- StephenBDec 08, 2018Guru - Experienced User
You can also do that with network permissions, just set the users to read only there and leave the file permissions alone.
How large are they?
Not really that large. The largest file is 5 gb and the smallest it will not delete is 1.5gb. It’s kind of weird since it had to delete these files before when backing up, since I have them set to delete all the files before backing up. I did that at first because I was changing the file locations often trying to be organized in a way that made them easy for me to find. Now that I have everything finally where I want it once I get this backup to run I will change it so it only adds the files that are different or not in the folders.
I will admit I have not been backing up more than 3 or 4 times a year since I got the system. I plan to change that after this final backup. I plan to backup at least once every 2 weeks.
- StephenBDec 09, 2018Guru - Experienced User
I don't think it's the size, but there could be something else going on with the file system.
You could try creating a new share, then use a web UI backup job to copy the files into it. Then delete the original share, and rename the new one to match the original.
BTW, you probably shouldn't enable snapshots on these shares (since the repeated deletions will consume a lot of snapshot space). If you want to take advantage of snapshots, you might want to look into tools that will do incremental backups from the PC (instead of using NAS backup jobs). FreeFileSync might be worth looking at. I've used RoboCopy to do this, though that is a command line tool so you'd need to create a script.
- StultisDec 13, 2018Aspirant
Hello, I have been trying to do as you suggested and keep encountering the same problem. I am unable to remove those files or delete that folder. I can add folders, but not delete that one.
I did finally see an alert pop up at the top and when checking the logs it said that “The volume encountered an error and was made read - only. It is recommended to backup your data.”
Could this have been my problem the whole time? How do I change it from read only?
I disabled snapshots not very long after getting the system. I was noticing that all my space was being used up by the snapshots.
I’ll give free file sync a look and see if it will help me backup faster and more efficiently.
- StultisDec 13, 2018AspirantHello,
It looks like anytime it encounters a conflict, me trying to delete those files or that share, it turns the system into a read only until after reboot. Then I can backup or move files, other than the handfull it has deemed off limits. Everything I check on those files seems to be just like the other files and folders on the system. It just does not like me trying to delete those specific files. I have tried moving them. It looks like the files have moved to another folder, but when I check after a few minutes they have either moved bock or the system never moved them. Then the system encounters a error and becomes read only until after reboot.
I might just leave those files alone and backup what needs to be backed up and move on to making it ftp ready. I can always try to delete them at a later date. - StephenBDec 14, 2018Guru - Experienced User
Perhaps look in system.log and see if there are any BTRFS errors around the time you tried to do the deletion.
- StultisDec 15, 2018Aspirant
Hello,
Here is all it says in the logs when I try to delete those files.
Is there another place I can check to see a different log? Maybe in more detail. I just went to system then selected log.
Thanks
- StephenBDec 16, 2018Guru - Experienced User
Download the log zip file and look in system.log and kernel.log.
- StultisDec 17, 2018Aspirant
Hello I found this in the system.log :
Dec 13 19:24:46 ********** apache2[14424]: [error] [client censored IPaddress] File does not exist: /var/www/currentsetting.htm
Dec 13 19:25:09 ********** afpd[15482]: dsi_tcp_open: invalid header
With a ton of lines around it saying it could not send an e-mail "has password changed in future"
In the kernel.log I found this:
Sorry For the badly stitched image. It was the fastest way I could think of to edit my systems name and IPaddress out.
Let me know if it is too small to see and I will upload it in a different format.
Thanks
- StephenBDec 18, 2018Guru - Experienced User
The characters aren't legible even when the image is zoomed. Cut-paste as text (using the "insert code" </> icon), and edit out whatever you wish there.
Private IP addresses are safe to post, as they are not routable over the internet. So your NAS can not be reached using them. The three private IP addresses ranges are:
10.0.0.0 – 10.255.255.255
172.16.0.0 – 172.31.255.255
192.168.0.0 – 192.168.255.255 - StultisDec 18, 2018Aspirant
Hello, I did what you suggested this morning before work, hit post. It looks like it did not post. I’ll try again once I get home tonight.
Hello,
It keeps telling me I do not have the correct privileges to post the code. I have tried a few times. Posting in the code icon and trying in the normal post.
Maybe this will work. I made a jpg using copy paste text into gimp2 and I am attaching it as a file. Since everytime I try to either enter it in as code or just paste it into the text section the post disappears. Hopefully it stays this time.
- StephenBDec 19, 2018Guru - Experienced User
Yes, that is a btrfs filesystem error. If you can't delete the share (recreating it later and restoring it from backup), the best way to fix it would be to do a factory reset and restore the entire NAS.
Perhaps try doing a scrub from the volume maintenance menu first, and see if that repairs it.
- StultisDec 19, 2018Aspirant
Thanks for the info. I’ll run the scrub, if that doesn’t work I guess I’ll have to do the restore.
- StultisDec 22, 2018Aspirant
Hello,
Shouldn’t I be able to still access my ReadyNAS while it is running a scrub? I cannot log into the admin page or use readycloud on any device. Does this mean it has frozen or crashed? The lights are still on, but they are not blinking like they usually do when it is workin.
- StephenBDec 23, 2018Guru - Experienced User
It should be accessible, but with much slower response.
Have you tried installing RAIDar on a PC, and see what status it reports? https://kb.netgear.com/20684/ReadyNAS-Downloads
- StultisDec 23, 2018Aspirant
Here is what it says when I run raidar. I guess I should unplug the device let it sit a few minutes then plug it back in.
