Stultis
Dec 01, 2018Aspirant
Trouble setting up FTP on ReadyNAS 102 with Linksys router EA6900
Hello, I am having trouble setting up my ReadyNAS for FTP. I have a Linksys router (EA6900) I am using for WIFI. I have the FTP enabled on the ReadyNAS and can see and use the FTP settings around my ...
Dec 14, 2018Guru - Experienced User
Perhaps look in system.log and see if there are any BTRFS errors around the time you tried to do the deletion.
Stultis
Dec 15, 2018Aspirant
Hello,
Here is all it says in the logs when I try to delete those files.
Is there another place I can check to see a different log? Maybe in more detail. I just went to system then selected log.
Thanks
- StephenBDec 16, 2018Guru - Experienced User
Download the log zip file and look in system.log and kernel.log.
- StultisDec 17, 2018Aspirant
Hello I found this in the system.log :
Dec 13 19:24:46 ********** apache2[14424]: [error] [client censored IPaddress] File does not exist: /var/www/currentsetting.htm
Dec 13 19:25:09 ********** afpd[15482]: dsi_tcp_open: invalid header
With a ton of lines around it saying it could not send an e-mail "has password changed in future"
In the kernel.log I found this:
Sorry For the badly stitched image. It was the fastest way I could think of to edit my systems name and IPaddress out.
Let me know if it is too small to see and I will upload it in a different format.
Thanks
- StephenBDec 18, 2018Guru - Experienced User
The characters aren't legible even when the image is zoomed. Cut-paste as text (using the "insert code" </> icon), and edit out whatever you wish there.
Private IP addresses are safe to post, as they are not routable over the internet. So your NAS can not be reached using them. The three private IP addresses ranges are:
10.0.0.0 – 10.255.255.255
172.16.0.0 – 172.31.255.255
192.168.0.0 – 192.168.255.255 - StultisDec 18, 2018Aspirant
Hello, I did what you suggested this morning before work, hit post. It looks like it did not post. I’ll try again once I get home tonight.
Hello,
It keeps telling me I do not have the correct privileges to post the code. I have tried a few times. Posting in the code icon and trying in the normal post.
Maybe this will work. I made a jpg using copy paste text into gimp2 and I am attaching it as a file. Since everytime I try to either enter it in as code or just paste it into the text section the post disappears. Hopefully it stays this time.
- StephenBDec 19, 2018Guru - Experienced User
Yes, that is a btrfs filesystem error. If you can't delete the share (recreating it later and restoring it from backup), the best way to fix it would be to do a factory reset and restore the entire NAS.
Perhaps try doing a scrub from the volume maintenance menu first, and see if that repairs it.
- StultisDec 19, 2018Aspirant
Thanks for the info. I’ll run the scrub, if that doesn’t work I guess I’ll have to do the restore.
- StultisDec 22, 2018Aspirant
Hello,
Shouldn’t I be able to still access my ReadyNAS while it is running a scrub? I cannot log into the admin page or use readycloud on any device. Does this mean it has frozen or crashed? The lights are still on, but they are not blinking like they usually do when it is workin.
- StephenBDec 23, 2018Guru - Experienced User
It should be accessible, but with much slower response.
Have you tried installing RAIDar on a PC, and see what status it reports? https://kb.netgear.com/20684/ReadyNAS-Downloads
- StultisDec 23, 2018Aspirant
Here is what it says when I run raidar. I guess I should unplug the device let it sit a few minutes then plug it back in.
