nickel22222
Jan 12, 2019Tutor
Trouble upgrading cpu on RNDP6000-100nas
I've been trying to upgrade cpu on RNDP6000-100NAS.
Came with E5300 2.6 ghz.
I have video to view and usb keyboard.
Dropped in replacement E2160 1.8 ghz.
After usb identified it...
- Jan 14, 2019It seems I needed the bios upgrade. It almost gave me a heart attack when I did it.
Once I updated bios the cpu upgrade allowed a boot. Maybe coincidence.
Couldn’t clear root error and couldn’t get to admin. Finally worked.
Had to downgrade then update then upgrade.
What a mess but now resyncing much faster.
kmassner1
Jan 13, 2019Guide
Isn't that a downgrade, or am I missing something? I went with E7600, and it runs cooler than stock.
I would think that if you're not able to get into bios, that the system is unhappy with the cpu. I tried some 1333 FSB cpu's (which didn't work) and on some experienced similar (although I'm not sure exactly the same) symptoms.
nickel22222
Jan 14, 2019Tutor
Sorry. I meant I am upgrading to 2.6 Ghz.
Funny thing is that at bios post it does show 2.6 Ghz on screen. SO that implies it does recognize it.
What key do I hit to bring up bios screen? Do I hold down or tap?
It stops just short of AHCI requests. No damage just not identifying AHCI stuff which boots into the OS.
Patrick
