Waffle2018
May 03, 2020Follower
Trouble with factory reset on ReadyNAS duo v2
Hi, Please help... I'm having trouble resetting it to factory settings; I have followed the reset procedure in Para 3 of the instructions here (http://www.downloads.netgear.com/files/GDC/RND2110/...
Sandshark
May 03, 2020Sensei
If you do actually have a V2, then following the instructions for a V1 won't get you where you want to be, The hardware manaual for the V2 is here: http://www.downloads.netgear.com/files/ReadyNAS_Duov2_NV+v2_HW_en_19-Sept-11.pdf .
Note that I say if because there can be confusion on the version. A true V2 says Duo V2 on the front and has a rear fan the full width of the chassis. V2 written on a sticker on the rear or bottom doesn't mean the same thing.
