Tonkinite
Mar 18, 2017Luminary
TWO ReadyNAS NV+(s) v1 available to a new home...
Have two NV+ available (original Netgear post Infrant v1s), upgraded to 1G, set aside drive less, were working fine after being upgraded to 4.1.15. If you send me a prepaid shipping label link, I...
- Apr 06, 2017
A HUGE thank you to Tonkinite for sending the spare chassis from USA to UK. No data loss, and everything also backed up to an external USB 3TB disk.
You have saved my life!!
Best wishes -- Peter
FramerV
Mar 21, 2017NETGEAR Employee Retired
Hi Tonkinite,
Thank you for being considerate about eWaste and such, although I do not think that support would be able to send a shipping label for that unit. You can probably check 3rd party electronic stores that might be able to refurbish the unit.
mdgm-ntgr
There's no warranty for second hand units (but in any case these units would be out of warranty by now).
The NV+ v1 is using the same CPU as a product released back in February 2006. It's pretty old hardware now and End of Life. At this point unless you're looking for parts to repair a unit you already have or would prefer to move your disks across from a dead NV+ v1 to another one I'd recommend buying a new ReadyNAS.
Even the most cost effective of our current models are much faster than the NV+ v1 was.
