FlaviaS's avatar
Apr 11, 2018
Ultra 2 vs. Pro 2
I have an Ultra 2 (1.8Ghz Atom D425 version) which I plan to upgrade to OS6. I was wondering if the software diferences present in Raidiator 4.x between Ultra 2 and Pro 2 (AD Integration, etc) are st...
  • StephenB's avatar
    Apr 11, 2018
    They should both have the same features.  There are a couple of features that are x86 only (ReadyDR, and the performance graphs for instance), but as far as I know they are available on all x86 platforms.
ProSupport for Business
