Impulse007's avatar
Impulse007
Ultra 4 Plus - Memory Upgrade
I am still running a Ultra 4 Plus and I'm looking to upgrade the memory from the 1 GB stock. From what little information I can find the Ultra 4 Plus uses DDR2 memory but I'm unclear if the maximum amount of memory supported is 2 GB or 4 GB. Do anybody know? Also, is there a specific memory model number I should look for, etc?
Thanks,
Matt
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Hi Impulse007
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
    The Netgear community looks forward to hearing from you and being a helpful resource in the future!
  • Marc_V's avatar
    Marc_V
    Hi Impulse007
    Here's a thread regarding advice on upgrading Memory.
    As mentioned, Ultra 4 plus is not supported anymore so you need to keep the old RAM in case of any issues you may encounter.
    Hope this helps!
    Regards
ProSupport for Business
