Ripperoo
May 21, 2011Aspirant
Ultra 4 Plus Memory Upgrade Advice Needed
I finally got myself a ReadyNAS 'Ultra 4 Plus' after what seems like an eternity. Got it for what I thought at the time was a decent price around two weeks ago for £418 and no it's dropped again t...
dbott67
May 21, 2011Guide
Although many folks have upgraded the RAM in their devices without issue, it should be mentioned that this is something that is no longer supported by Netgear. If you decide to upgrade, you should keep the old memory module to swap back in the event of problems. Having said that, TecknoJnky had success with PC2-5300:
TeknoJnky wrote: working so far Model: ReadyNAS Ultra 4 [X-RAID2]
Firmware: RAIDiator 4.2.16-T25
Memory: 3968 MB [DDR2]
http://www.newegg.com/Product/Product.a ... 6820220495
Patriot 4GB 200-Pin DDR2 SO-DIMM DDR2 667 (PC2 5300) Laptop Memory Model PSD24G6672S
69.99
