Ripperoo
May 21, 2011Aspirant
Ultra 4 Plus Memory Upgrade Advice Needed
I finally got myself a ReadyNAS 'Ultra 4 Plus' after what seems like an eternity. Got it for what I thought at the time was a decent price around two weeks ago for £418 and no it's dropped again t...
dbott67
May 26, 2011Guide
Personally, I would feel pretty confident. The jedis recommend running the memtest at least twice (apparently memtest only has an 85% success rate for flagging bad memory - faq.php#Is_there_a_way_I_can_verify_if_my_memory_is_good%3F).
Just keep an eye on the system and be prepared to swap the old memory back in the event of problems. Any problems may not necessarily be caused by the new memory, however, being able to swap back would help eliminate/isolate the problem.
-Dave
-Dave
