Ripperoo
May 21, 2011Aspirant
Ultra 4 Plus Memory Upgrade Advice Needed
I finally got myself a ReadyNAS 'Ultra 4 Plus' after what seems like an eternity. Got it for what I thought at the time was a decent price around two weeks ago for £418 and no it's dropped again t...
ewickham
Feb 13, 2014Aspirant
fastfwd, the Micron part number is MT16JSF25664HZ-1G1F1 1012. There is another number referenced on the label, I doubt it's relevant, but it's listed on the line "Product of China DPAA7E5013". The memory on the Micron chips is mounted on both sides of the PCB, while the memory that ships with the unit only has chips on one side. I found a one-sided 2GB module from Corsair that' may be applicable. CM3X2GSD1066.
