Ripperoo
May 21, 2011Aspirant
Ultra 4 Plus Memory Upgrade Advice Needed
I finally got myself a ReadyNAS 'Ultra 4 Plus' after what seems like an eternity. Got it for what I thought at the time was a decent price around two weeks ago for £418 and no it's dropped again t...
fastfwd
Feb 13, 2014Virtuoso
ewickham wrote: fastfwd, the Micron part number is MT16JSF25664HZ-1G1F1
Yeah, that's a dual-rank module, so it won't work. http://www.micron.com/parts/modules/ddr3-sdram/mt16jsf25664hz-1g1
It isn't "equivalent" to the Corsair module. Return it, if you can, and demand either the Corsair part you ordered or your money back.
ewickham wrote: I found a one-sided 2GB module from Corsair that' may be applicable. CM3X2GSD1066.
I can't find any detailed specs on that module, but the one-sidedness is a good indication that the memory organization is single-rank and that it would therefore work.
The necessary specs for compatibility with your Ultra 2 Plus are in this post: http://www.readynas.com/forum/viewtopic.php?f=110&t=52557&start=15#p379994
Good luck...
